LaidtTech CULT-Urgestein
Verfasst am: 08.01.2010, 00:10 • Titel: |
Dieses mal mit an Bord : Rock Crawler mode
Na , wenn das mal nix ist ...
Description:
This is the Hobbywing Xerun-80A brushless system for 1/8 buggy/truggy/monster truck
Feature:
For: 1/8 buggy/truggy/monster truck, Color: Blue, Compatible with all sensorless brushless morots and most of the sensored brushless motors such as LRP, SpeedPassion, Novak, etc, Seamlessly change to sensorless working mode when the sensor cable is broken, Excellent start-up, acceleration and linearity features, Built-in switch mode BEC has a powerful output to supply all the electronic equipments, Firmware can be updated through an USB adapter on the advanced LCD Program Box (Optional Equipment) User programmable. Easily programmed with the "SET" button on the ESC and also compatible with the 3 digit LEDs Program Card and the advanced professional LCD Program Box, 3 running modes (Forward mode, Forward/Reverse mode, Rock Crawler mode) 4 steps of maximum reverse force adjustment, Proportional ABC brake function with 4 steps of maximum brake force adjustment, 8 steps of drag-brake force adjustment and 4 steps of initial brake force adjsutment, 9 start modes (Also called "Punch") from "very soft (Level 1)" to "very aggressive (Level 9)", 8 steps of timing adjustment to suit for all brushless motors, Multiple protection features: Low voltage cut-off protection / Over-heat protection / Throttle signal loss protection / Motor blocked pretection, Splash proof and dustproof
ESC Specification:
Cont./Burst Current: 80A/380A, Resistance: 0.0006ohm, Suitable Car: 1/8 on-road, off-road, monster RTR applications, Suitable Motor: Sensored and sensorless brushless motor (>=6T, KV<=2400), the 80A ESC works with 4S Lipo, Battery: 6-12 cells NiMH or 2-4 cells Li-Po, BEC Output: 5.75V@3A Switch mode built-in BEC, Dimentions: 58mm(L) x 46.5mm(W) x 35mm(H), Weight: 105g (Wiers not included), Cooling Fan Working Voltage: 5V, maximum 8V (The fan gets the power supply from the built-in BEC) _________________ http://mtb-support.de |
rcflitzer Streckenposten
Anmeldedatum: 14.04.2009 Beiträge: 16
Verfasst am: 26.01.2010, 21:05 • Titel: |
Hallo
hab mir die 150 A combo ( 2000kv Motor ) in China bestellt, Preis sehr gut Lieferung sehr schnell 4 Tage. Habe ihn in den Summit verbaut.
Bin absolut zufrieden, kein cocking, Temperatur auch ok, obwohl mann bei den Temp. momentan da noch keine klare Aussage treffen kann.
lg _________________ E-savage
E-revo mit Mamba Monster brushless
savage flux
Summit mit 2000kv xerun
Hobbytech STR 8ep |
Gipfelstürmer neu hier
Anmeldedatum: 02.02.2010 Beiträge: 1
Verfasst am: 02.02.2010, 22:16 • Titel: |
Hallo rcflitzer,
ich hab auch nen Summit und möchte mir jetzt auch gern ein BL Set reinpacken. Du hast ja auch das Mamba Monster Set, welches würdest du mir empfehlen?
Ich hab mir gerad 2 neue 7 Zeller NiMh besorgt und würd die gern auch noch weiterfahren. Ich will erstmal nur ein wenig mehr Endgeschwindigkeit. Wie funzt das Crawlen mit dem BL? kein Problem oder ist Brushed doch besser?
Muss man eigentlich Zoll bezahlen wenn das Ding auch China kommt? Wenn ja, wie viel?
Danke schonmal  |
Kub CULT-Urgestein
Verfasst am: 02.02.2010, 22:28 • Titel: |
hallo und herzlich willkommen!
damit ich nicht möchte, dass du dir die finger verbrennst vorab gleich die warnung: fragen zum thema
| Zitat: |
sind in diesem forum bereits zur erschöpfung besprochen worden und haben erst kürzlich etwas unmut bei den Mods hervorgerufen, da nur noch solche themen hier besprochen wurden.
Benutze bitte die suchfunktion um dich über zoll etc zu informieren.
lg _________________ OC-BASH Mai 2011:
