Scale-Crawler => Wieder was Neues von Axial.
offroad-CULT Forum » RC Offroad News » Scale-Crawler => Wieder was Neues von Axial. » Gehe zu Seite Zurück  1, 2, 3 ... 11, 12, 13
    Canneloni
    Anmeldedatum: 22.06.2009
    BeitragVerfasst am: 09.07.2011, 11:11    Titel:
    JA es sollte ein zettel dabei sein.....
    Selbst bei den Günstigsten China reglern war bis jetzt immer ein zettel bei wie man es macht.....
    the_transporter
    Anmeldedatum: 27.01.2010
    BeitragVerfasst am: 09.07.2011, 11:36    Titel:
    ich zitiere an dieser Stelle Mal aus einem anderen Forum:
    ---Guy from Austraila just hacked the stick program for the AE-2!
    "I have worked out how to program some features of the AE-2 without using Castle Link. Like the Castle Creation SideWinder ESC, the standard way of getting into the programming mode is as follows. You may want to disconnect your motor from the ESC first to avoid the chance of a runaway.
    1. Switch off the ESC
    2. Switch on the transmitter and hold full throttle
    3. Switch on the ESC
    4. Release the throttle AFTER the second series of tones
    The ESC uses tones to indicate what Options you are currently accessing and its setting. eg. Option 2 setting 3 will be "beep-beep, pause, beep-beep-beep". You accept the setting for the option by engaging full throttle, or you can go to the next setting by engaging full reverse. Once you have configured the last option, the ESC will emit a series of tones and when that is finished the settings are stored.
    There are 3 Options available and here are the Settings available:
    Option 1 - LiPo CutOff (I think, please test first)
    Setting 1 - Off
    Setting 2 - On
    Option 2 - Drag Brake
    Setting 1 - Off
    Setting 2 to 6 - varying degree
    Option 3 - Brake/Reverse type
    Setting 1 - Forward-Brake-Reverse
    Setting 2 - Forward and Brake only
    Setting 3 - Forward and immediate reverse
    fideliovienna
    Anmeldedatum: 17.06.2010
    BeitragVerfasst am: 09.07.2011, 11:57    Titel:
    Wenn kein Zettel dabei ist, es ist ja ein Castle-Regler, also:
    http://www.castlecreations.com/support/documents/drivers_ed_guide.pdf
    EDIT: Find ich süss dass jemand von "hacken" der Programmierung eines Castle-Regler spricht Laughing
    stsielaff
    Anmeldedatum: 28.08.2009
    BeitragVerfasst am: 09.07.2011, 12:01    Titel:
    Also das ist glaub ich auch das kleinste Problem. Hab in letzter Zeit viel gelesen und auch gerade zu dem Auto hier, viele haben/ hatten Probleme beim Binden mit der Funke, aber zum programmieren selber eher keine.
    Anderes Problem, korrigiert mich bitte, bin neu, ist die Blance bzw. das Gewicht auf der Vorderachse fehlt. Und die Felgen sind geklebt, also da Gewichte reinbauen wird dann schwierig.
    Und einige haben schon die Anlenkung nach hinten gebaut, also hinter die Vorderachse. Versteh den Sinn nicht ganz, vielleicht kann das wer erläutern bitte?
    HongNor DM One
    Zelter Frost
    Anmeldedatum: 09.06.2008
    BeitragVerfasst am: 09.07.2011, 12:05    Titel:
    stsielaff hat Folgendes geschrieben:
    Ist doch logisch: so bleibt man mit der Anlenkung nicht hängen, das rauffahren auf Felsen und Hindernissen allgemein ist einfacher
    Ryan Dunn
    R.I.P. Bro
    stsielaff
    BeitragVerfasst am: 09.07.2011, 12:08    Titel:
    Macht man doch eher sowieso nicht direkt oder? Bzw. sind die Räder ja eher am Felsen als die Lenkung. Ist das ein häufiger Schaden am Auto? Also meine sollte man davon genug Teile auf Lager haben?
    HongNor DM One
    Zelter Frost
    BeitragVerfasst am: 09.07.2011, 12:24    Titel:
    das Gelände ist ja nicht immer eben Wink so daß ausschliesslich die Reifen Kontakt mit den Felsen haben/hätten
    Ryan Dunn
    R.I.P. Bro
    the_transporter
    BeitragVerfasst am: 09.07.2011, 12:25    Titel:
    fideliovienna hat Folgendes geschrieben:
    da musste ich auch etwas schmunzeln, darum hab ich diesen Teil noch mitkopiert Razz
    Fluxfahrer
    Anmeldedatum: 08.02.2011
    BeitragVerfasst am: 09.07.2011, 12:35    Titel:
    Ich wollte mich mal ganz nebenbei für die wertvollen Tipps bedanken, bis jetzt konnte ich bei Castle Reglern (bzw. beim MMP von meinem Savage Flux 2350) lediglich nur den Lipo-Cutoff und das Programmieren mit dem Empfänger programmieren Wink Nun weiß ich mehr Razz
    Fuhrpark:
    - HPI Savage Flux XL *Custom*
    - ultimate STUGGY
    - 2x HPI Savage Flux HP
    - Losi Micro DT
    - Losi Micro Highroller
    BMW E34 540iT/6 #302/499
    Keine neuen Beiträge Hallo mal wieder :) Crasher125 1 29.06.2019, 19:32
    Keine neuen Beiträge Neues zum bashen Sandflo 4 05.08.2018, 10:56
    Keine neuen Beiträge Wieder Einsteiger mit Sohnemann stefan1980 11 01.05.2017, 12:36
    Keine neuen Beiträge Bin ich verrueckt? Such was neues zum Bashen... Wu134 7 29.03.2017, 20:51
