Brushless bald "Salonfähig"?
offroad-CULT Forum » Elektro - 1/8 » Brushless bald "Salonfähig"? »
    BeitragVerfasst am: 30.05.2004, 19:03    Titel: Brushless bald "Salonfähig"?
    Bei den US ROAR-sanktionierten Nationalläufen gibt's erstmals eine Brushless "Demonstrations" Klasse für Buggys und Stadium Trucks!
    Der Veranstalter-Club:
    http://rcdirttrack.com/arcor/
    Novak ist einer der Hauptsponsoren, und so sind (verständlicherweise) leider nur Novak SS bestückte Modelle erlaubt.
    Hier jedenfalls ein Auszug aus dem allgemeinen BL-Regelment:
    Quote:
    BRUSHLESS ELECTRIC MOTORS
    1. Overall maximum diameter is 36.02mm measured at whatever point yields the maximum dimension, excluding solder tabs or lead wires. Maximum length is 53mm measured from the mounting face of the motor to the furthest most point of the end bell, not including solder tabs, lead wires or original manufacturer’s logo or name. Shaft diameter must be 0.125”. Motor mounting holes must be on 1.00- inch centers. Only two pole bonded neodymium or ferrite magnetic rotors are permitted. The stator laminations must be one after another all of the same magnetizable material without anything in between. No split stators allowed. Maximum stator length must be 0.80” +/- 0.01”. Inside diameter of the stator must be 0.5850” +/- 0.0005”. Only three slot “Y” (star) wound stators are permitted. No delta wound stators allowed. Only circular (round) pure copper wire allowed for the stator. . Magnet specifications. Length 1.00” +/- 0.005”. Diameter= 0.5510” +/-0.0040”. Weight of rotor including shaft, hub and magnet =1.00 oz. +/- 0.05oz.
    All motors must have the original manufacturer’s logo or name molded into the end bell. Sensored or sensorless motors are allowed. For compatibility purposes, if the motor is sensored it must use a six position JST ZH connector model number ZHR-6 or equivalent connector with 6 JST part number SZH-002T-P0.5 26-28 awg contacts or equivalent. Wire sequence must be as follows. Pin#1- Black wire ground potential, pin #2- orange wire phase C, pin #3- white wire phase B, pin #4- green wire phase A, pin #5- blue wire temp control, 10 k Thermistor referenced to ground potential, pin #6- red wire + 5.0 volts d.c. +/- 10%. Compatible speed control must use the 6 position JST header part number X-6B-ZR-SMX-TF (where the X denotes the style of the header), or equivalent. Motors must be rebuildable
    auf Deutsch heißt das:
    allgemein
    - max. Motor Durchmesser: 36,02mm mit 25mm Lochkreis
    - max. Gehäuselänge: 53mm
    - Wellendurchmesser: 3,18mm
    - max. Polzahl: 2
    Stator
    - max. Länge 20,32mm (+/- 0,25mm)
    - keine Luftspulenwicklung
    - Wicklung ausschließlich aus rundem Draht
    - nur Sternschaltung zugelassen
    Rotor
    - Länge x Breite = 2,54 x 1,4 mm
    ... obwohl auch Sensorlose Motoren anderer Hersteller "prinzipiell" erlaubt sind, kenne ich keinen anderen Motor, der ein Kunststoff Lagerschild mit Herstellerprägung trägt, von den geringen Toleranzen ganz abgesehen...)
    Interessantes Detail am Rande - der Novak Motor besitzt eine Sternschaltung!
