Asbjörn Pisten-Papst
Anmeldedatum: 20.11.2008 Beiträge: 418 Wohnort: Lübeck
Verfasst am: 05.01.2011, 13:32 • Titel: Hobbytech Re-Volt BX 10 |
This is the latest car from Hobbytech, an 1/10 Electric Powered 4WD Off Road Buggy. Get your hands on a dominant racing machine, at an affordable price ! This package makes the perfect partner for your first shot at EP off-road racing. The car is fully adjustable and offer a very goog handling.
Re-Volt BX-10 Ready Set contents :
* Battery Ni-Mh 7.4V 2000mAh
* Transmitter and R/C System with EPA setup
* Steering Servo 3.5kg
* Stock Motor
* ESC
* 220V Battery Charger
Re-Volt BX-10 Features :
* 4WD - EP racing buggy with center shaft drive 4WD.
* Ready To Run - Fully factory assembled Readyset.
* High Power Stock Motor - Loaded with high-power user-friendly stock motor and compact high-power speed controller (pre-set).
* Better Balance - The drive shafts run through the center for chassis to give you better lower CG and optimum weight balance.
* Equiped With Ball Bearings - Includes total of 20 ball bearings for full ball bearing specifications.
* Oil Filled Shocks - Equipped with Aluminium oil shocks. Dial-adjust function for easy setting.
* Slipper Clutch - Features slipper clutch as standard to protect drive mechanism and deliver optimal traction.
* Front & Rear Ball Diff - Equipped with ball differentials on front and rear as standard.
* High Strength & Rigidity - Resin chassis combines with X-backbone upper deck for high strength and rigidity.
* Fully Adjustable Turnbuckles - Turnbuckle upper arms and 4-wheel independent double-wishbone suspension.
* Sway Bar - Equiped with front and rear sway bar.
* CVD - Equiped with CVD front shaft
Link Zur Seite:http://hobbytech-rc.imodel-pro.com/car.php?id=160
Preis:ca 180€
mfgAsbjörn _________________ VG von der Ostsee...
->Daraufhin erfand der Teufel LiPo und Brushless. |
Dirt_Basher Werkstatt-Meister
Anmeldedatum: 02.01.2011 Beiträge: 160 Wohnort: Hessen
Verfasst am: 05.01.2011, 15:57 • Titel: |
find ich für einsteiger sehr interessant
wäre Konkurenz zu der S10 Reihe von LRP
Optisch stark geschmackssache meiner meinung nach
Erinnert mich so auf den Blick an eine mischung aus Durga und Lazer ZX-5
rein Optisch
Weiß jemand wieviel turn der motor hat?
Dirt_Basher _________________ Gruß Julian
Suche Fahrer in der nähe von Dieburg |
Verfasst am: 05.01.2011, 16:29 • Titel: |
Der Motor wird warschenlich wie der vom Blast (LRP) auch max 20 turns haben.
mfg Asbjörn.
p.s.:Auch mir gefällt der Wagen!! _________________ VG von der Ostsee...
Raphael Pisten-Papst
Verfasst am: 05.01.2011, 16:30 • Titel: |
Hätte man das HZ ans Chassisende gebracht, könnte man den Akku auch weiter in Richtung Wagenmitte schieben.
Dann sollte man lieber die Diffs drehen, den Motor nach rechts vorne packen und hinten Saddlepacks reinpacken (was ja nun wirklich eine gaaanz neue Aufteilung wäre), so wirkt es, naja, unfertig. _________________ Short Course - Übersicht der Radstandards
Verfasst am: 05.01.2011, 16:32 • Titel: |
VIlleicht von der Aufteilung nicht Perfekt,aber zum Bashen sollte es ja reichen.
Sonst müsste man ja wieder andere Akkutypen kaufen.
mfg Asbjörn _________________ VG von der Ostsee...
Verfasst am: 05.01.2011, 16:52 • Titel: |
Habe gerade noch gesurft:
Der erinnert mich an ein Caster SK-10A
http://www.casterracing.com/car/main_view.php?cid=1&iid=19
Hat der eine Rutschkupplung?
mr. pompadour Werkstatt-Meister
Anmeldedatum: 29.12.2008 Beiträge: 195 Wohnort: konstanz
Verfasst am: 05.01.2011, 17:10 • Titel: |
ich finde den wagen auch recht interessant sowohl preislich als auch optisch,vorallem die süssen bigbores sind sehen geil aus!  _________________ HB lightning stadium sport (bald brushless)
slash 4x4 fully rpm tuned
e-firestorm+genius90+dr.speed12t
carson specter+LRP Z21.R spec.3
axial xr10 powerd by holmes |
Verfasst am: 05.01.2011, 17:16 • Titel: |
@asbjörn
ja er hat einen slipper
http://www.casterracing.com/news/main_view.php?cid=7&iid=59&id=813
ziemlich mittig im text
@Raphael
Dann sollte man lieber die Diffs drehen, den Motor nach rechts vorne packen und hinten Saddlepacks reinpacken (was ja nun wirklich eine gaaanz neue Aufteilung wäre) |
du meinst so:
das wäre dann der Caster
und unfertig finde ich sieht der net aus geschmackssache halt
@hegelber
find ich auch sind die aus alu oder nur grauem plastik
Verfasst am: 05.01.2011, 17:53 • Titel: |
Sorry hab ich Übersehen mit dem Slipper.Auf den Fotos sah man nix.
Ich finde die Karre irgentwie cool.
Leider gibts noch keine Lieferauskunft.
Bei mir kommt das "Will HABEN" Syndrom durch  _________________ VG von der Ostsee...
modell-bomber Offroad-Guru
Verfasst am: 05.01.2011, 18:45 • Titel: |
hi, echt schicke karre!
finde ich irgendwie lustig, dass sich das mittige HZ immer stärker verbreitet...
kannte man ja eigentlich nur aus dem wb-bereich.
und für mich sehen die dämpfer ganz klar nach alu aus.
kann man z.B. gut am gewinde erkennen. |
