RC Sequoia Hop-Up Held
Anmeldedatum: 08.12.2009 Beiträge: 108 Wohnort: Niederösterreich
Verfasst am: 05.01.2010, 15:59 • Titel: Kyosho Inferno MP9e |
Wahrscheinlich ab Februar 2010 am Markt: Kyosho Inferno MP9e
The most successful chassis in history is now available in a brushless powered platform. Same MP9 performance with the ease of EP power. Advanced components create a synergy of pure performance. With 7 World Championship victories, the most successful racing buggy that the world has ever seen has undergone its first full model change for the 21st Century. Everything down to the last ball-end has been recreated with the focus on maximum speed and performance in a completely new chassis and body development. Overall weight balance compliments the lightweight chassis that covers setting options for all inputs to lateral running characteristics.
* Ultra Low C.O.G - Ultra low center of gravity, lightweight and optimal weight balance all combine to deliver the ultimate racing weapon.
* New Body Design - Newly developed body is slimmer and lower in height to realize aerodynamic characteristics for powerful down force and full inner cooling.
* More Down Force - Bolted on large wing generates powerful down force. New ribbing at the back results in improved rigidity.
* Composite Torque Rods - Roll center can be adjusted by changing the direction of the spacer inserted into the lower arm of the rear suspension. Also, the one-piece ball and washer ball-ends are an added maintenance feature.
* Upright Servo - Servo is mounted upright for easy maintenance and is dropped 2mm to contribute to the lower center of gravity.
* Extremely Light Weight - The smaller differential units on front and rear with grooved cup joints, aluminum balls and the flexing shape of resin parts effectively lightens the weight while giving the chassis rigidity, more durability and strength.
* Wraparound Side Guards - Grooved face in side guard matches the thickness of velcro tape and prevents dirt getting inside the chassis. Complete wraparound side guards only found on Kyosho MP9.
* Equipped With Mud Guards - Mud guards on the rear arm prevent dirt entering the drive shaft and getting inside the wheels.
* We Have You Covered - 3 types of servo horn included for various R/C systems (SANWA / KO / for JR, FUTABA and Hitech)
* Hex Screws - Kit includes all hex screws enough said!
* New Suspension Design - Newly developed suspension uses bushing for easy maintenance and rationalizes the setting order.
* Increased Diff Case Capacity - Center differential realizes improved heat dissipating brake disc and increased case capacity for stable control through to the end of the race.
* Optimal Race Settings - Fine tune for the optimal race setting with adjustments to wheelbase, tread, roll center, caster angle, toe angle and camber change.
* EZ Motor Mount - The Inferno MP9e is equipped with Kyosho's own EZ gear mesh motor mount, all it takes is two simple screws and slide the whole motor till you get the perfect mesh.
* Lightweight Universal Driveshafts - The new driveshafts feature a lightweight design and are made from durable steel. Installed at the front, center and rear of the drivetrain, all of the driveshafts feature a distinctive black finish.
* Standard 17mm Hubs - Now you can use all standard 17 mmm wheels.
* Full Ball Bearings - Full ball bearings throughout for maximum efficiency through the drive system.
* New Medium Rear Shock Tower - The MP9e is equipped with the latest components like the new Medium rear shock tower that helps out in difficulty situations by giving you better handling in certain situations.
* World Championship Quality - The suspension features double A-arms, which is the same type of suspension used on the world's most sophisticated performance machines. It's durable so have the confidence that it's going to hold up even under extreme conditions.
Quellen
KyoshoAmerica
RCWORLD.ch _________________ *************************************
** Inferno VE *** Hyper 8.5 ** Savage 4.6 **
Fesler Pisten-Papst
Verfasst am: 05.01.2010, 21:36 • Titel: |
Schaut doch gar nicht mal so schlecht aus. Ist das ein Kunststoff-Chassis oder sieht das nur so aus?? (Hab da bei meinem E-Maxx schlechte Erfahrungen gemacht...)
Ist so ein Schutz an den hinteren Querlenkern notwendig?? |
Verfasst am: 05.01.2010, 22:33 • Titel: |
Fesler hat Folgendes geschrieben: |
Wie bei allen aktuellen Infernos: Chassis ist Alu, Seitenschutz Kunststoff.
Der Schutz der Hinterachse wurde beim MP9 eigtl. u.a. gegen Öl etc. vom Nitro-Antrieb "verkauft" ....... ist sicher nicht lebenswichtig. _________________ *************************************
jürgen_jl Kiesgruben-King
Anmeldedatum: 10.09.2008 Beiträge: 61
Verfasst am: 11.01.2010, 23:37 • Titel: |
Unwissende Frage: wo liegt da der Unterschied zum Inferno VE? _________________ Gruss
Jürgen
Durango DEX410, Schumacher CAT SX, CAT 2000, Fireblade USA, SST Axis, Asso SC10, Tamiya TT-01, Tamiya F104 |
gonzo Pisten-Papst
Verfasst am: 12.01.2010, 10:03 • Titel: |
Wenn ich mich nicht irre ist die Basis für den VE der Inferno 7.5 US Sports 2.
Have fun Gonzo
www.pimpmyrc-car.com |
Verfasst am: 12.01.2010, 14:34 • Titel: |
.... und die Basis des MP9e ist eben der MP9  _________________ *************************************
BacardiRazz Offroad-Guru
Verfasst am: 12.01.2010, 15:34 • Titel: |
...und mit Sicherheit liegen da Welten zwischen .Macht nen sehr aufgeräumten Eindruck.Schon alleine die Verstellung des Motorhalters....schick,schick
Was wird der wohl kosten!? _________________ -Losi 8ight 2.0 EU
-Hobao Hyper ST Pro
-Kyosho Ultima DB
-Ansmann Macnum BL |
Verfasst am: 12.01.2010, 19:39 • Titel: |
BacardiRazz hat Folgendes geschrieben: |
Was wird der wohl kosten!? |
An die 700.00 EUR wird man wohl rechnen können - ich weiss nicht, ob es ein RTR oder ein Kit wird (der MP9 ist ja ein Kit). _________________ *************************************
Verfasst am: 19.01.2010, 23:50 • Titel: |
Habe jetzt ersten Preis gefunden: US$ 749.99 = € 524.50
Was beinhaltet ist:
Kit Contents:
* Rolling Chassis (Kit)
* Mod 1 Steel Pinion Gear
* Clear MP9e Body
* Decals
* Hex Wrenches
* Cross Wrench
* 17mm Wheel Wrench
Quelle _________________ *************************************
swfan Hop-Up Held
Anmeldedatum: 01.06.2009 Beiträge: 76 Wohnort: irgendwo in Dresden
Verfasst am: 03.02.2010, 23:21 • Titel: |
Servus,
hab mal den Preis für den MP9e bei meinem Händler erfragt, der sehr gute Beziehungen zu Kyosho Deutschland hat. Soll laut Liste 549 EUR kosten. Verfügbarkeit steht aber noch in den Sternen. Nach diesem WE (Nürnberg) sind wir wohl aber schlauer.  _________________
Savi Flux uvm. |
