Losi 8ight 3.0
offroad-CULT Forum » RC Offroad News » Losi 8ight 3.0 »
    modell-bomber
    Anmeldedatum: 30.10.2009
    BeitragVerfasst am: 30.01.2013, 15:43 •   Titel: Losi 8ight 3.0
    Neuer Losi 8ight 3.0:
    Key Features
    Improved Suspension Geometry
    Large-bore 16mm Shocks with Tapered Springs
    Center Dog Bone Drive System
    Includes Optional Lightweight Outdrives, 48T Spur Gear, Adjustable Hinge Pin Braces and Aluminum Rear Bearing Inserts
    Gen 3 Radio Tray
    Adjustable Aluminum Front and Rear Pivots With Inserts
    Brake Caliper Springs
    Improved Body and Wing
    Optional Wickerbill (sold seperately)
    Aluminum Bearing Insets
    Multiple Sway Bars Included
    5mm Turnbuckles
    Improved Titanium Carbo-Nitride Shock Shaft and Hinge Pin Coating
    Metal Servo Insets
    Improved Droop Screw System
    The tradition of winning and dedication to superior engineering continues with the next generation of RC racing’s innovative buggy. Building upon the heritage of the 8IGHT™ buggy, the 8IGHT 3.0 elevates perfection and is poised to dominate the track. Guided by some of racing’s top drivers worldwide, the 8IGHT 3.0 buggy was designed to be the superior choice in 1/8-scale off-road buggy racing and a true contender for the world stage.
    Product Specifications
    Type: Buggy
    Scale: 1/8
    Length: 19.6 in (497mm)
    Width: 12.1 in (308mm)
    Height: 7.1 in (180mm)
    Ground Clearance: 2.4 in (60mm)
    Wheelbase: 12.7 in - 12.9 in (323-327mm)
    Weight: Varies on equipment used
    Chassis: 4mm, 7075 T-6 Aluminum, Hard Anodized
    Suspension: Independent
    Drivetrain: 4WD
    Wheel Size: 3.3 in (83.5mm)
    Kit/RTR: Kit
    Shock Type: Aluminum Oil Filled
    Body: 8IGHT 3.0, Unpainted
    Fuel Tank Capacity: 125cc
    Minimum Age Recommendation: 14 years
    Recommended Environment: Outdoor
    Is Assembly Required: Yes
    Needed to Complete
    - .21–Size Nitro Engine
    - 1/8-Scale Exhaust System
    - 2- to 3-Channel Radio System
    - Receiver Pack and Charger
    - Starter Box
    - Glow Igniter
    - Nitro Fuel
    - Fuel Bottle/Fuel Gun
    - Polycarbonate-Compatible Paint
    - Modeling Tools
    - 1/8-Scale Off-Road Buggy Tires and Inserts
    http://www.tlracing.com/Products/Default.aspx?ProdId=TLR04000
    CamelFilters
    Anmeldedatum: 09.12.2011
    BeitragVerfasst am: 30.01.2013, 16:43 •   Titel:
    musthave <3
    Losi 8ight-e 2.0, MEGA 2250, MMM/ Sirio CL7B
    TRF 501X WE, Sidewinder V3, CC 4POL 6900KV
    Losi XXX-CR, Twist 47, Jazz 70 Car
    HPI Savage, Force .38 CNC
    Keine neuen Beiträge Losi TEN-SCTE 3.0 MastaP 0 24.06.2017, 14:01
    Keine neuen Beiträge Losi Strike Setupempfehlung b.brain 3 05.05.2017, 20:03
