Losi High Roller Lifted Truck RTR
offroad-CULT Forum » RC Offroad News » Losi High Roller Lifted Truck RTR »
    Chimera
    Anmeldedatum: 03.05.2008
    BeitragVerfasst am: 13.01.2009, 06:42    Titel: Losi High Roller Lifted Truck RTR
    Und wieder ein super Modell aus der Schmiede Losi. Diesmal ein realitätsnaher 1/10 Scale Truck. Der Truck verfügt über folgende Specs:
    Features
    * Scale, extended cab detailed truck body
    * Detailed, realistic tube-style chassis
    * Front and rear skid plate for scale appearance and protection
    * Realistic vertical (standup) front and rear silver with blue highlighted anodized shocks
    * 320-Series chrome wheels with low profile all-terrain tires
    * Easy access battery compartment accommodates standard 6-cell NiMH packs
    * Reliable planetary gear differential for increased durability
    * Captured rod ends for less ball pops and increased suspension durability
    * Losi 27MHz AM receiver and transmitter available in six frequencies
    * LM-32K performance motor for great speed acceleration
    * 12RB Electronic Speed Control with reverse to back out of undesired situations
    Product Specifications
    Type:Electric Off-Road Truck
    Scale:1/10
    Length:18.5 inches (470mm)
    Width:12.75 inches (324mm)
    Wheelbase:12 inches (305mm)
    Chassis:Tube-Style
    Suspension:Four Wheel Independent
    Drive Train:Sealed 3-Gear Transmission
    Tire Type:Low-Profile, All-Terrain
    Motor or Engine:LM-32K Performance Motor
    Speed Control:Losi MSC12RB
    Radio:Losi MRX15 27MHz AM Receiver
    Batteries:6-Cell NiMH with Tamiya-Style Connector (sold separately)
    Charger:sold separately
    Wheel Size:320-series, Chrome
    Kit/RTR:RTR
    Shock Type:Oil-Filled, Anodized Aluminum
    Body:Fully Detailed, Extended-Cab Truck
    QUELLE:LOSI
    Caballero
    Anmeldedatum: 21.07.2008
    BeitragVerfasst am: 13.01.2009, 08:53    Titel:
    Very Happy
    Sieht echt super aus, der Truck. Aber seh ich das richtig, dass der (wieder nur) 2WD hat?
    Auf der LOSI-HP läßt sich dazu nichts ableiten, aber auf den Bildern kann ich auch keine Knochen an der Vorderachse identifizieren.
    Wär sehr schade, weil ich schon lange auf einen vernünftigen 1:10er-4WD-Truck warte. Und kurz hat mein Herz jetzt wirklich um einiges höher geschlagen...
    BlackWind
    Anmeldedatum: 17.01.2005
    BeitragVerfasst am: 13.01.2009, 12:12    Titel:
    der is schon was älter:
    http://www.offroad-cult.org/Board/losi-high-roller-1-10-semi-scale-rtr-t8795.html
    Chimera
    BeitragVerfasst am: 13.01.2009, 12:44    Titel:
    Da haben die aber lange gebraucht, von der Ankündigung im August bis zur Auslieferung im Januar :-S
    Rx*
    Anmeldedatum: 06.07.2007
    BeitragVerfasst am: 13.01.2009, 13:55    Titel:
    Ich sag nur eins: Traxxas Stampede Wink
    Mahoney
    Anmeldedatum: 08.08.2008
    BeitragVerfasst am: 13.01.2009, 14:07    Titel: lange?
    also august bis januar geht doch noch. es scheint bei vielen herstellern normal zu sein einen prototypen vorzustellen, den irgendwo testen zu lassen aber dann zu verschweigen, ob eine produktion wirklich stattfinden wird. es wird durch solche ankündigungen lediglich marktforschung betrieben. wenn das interesse dann nicht so groß ist wie erhofft, gerät so eine produktvorstellung sehr schnell in die unterste schublade der einzelnen firmen. oder glaubt ihr ernsthaft wenn ein artikel in einer fachzeitschrift getestet oder vorgestellt wird, dass dieser dann auch wirklich (in absehbarer zeit) im handel erhältlich sein wird? das dürfte in der heutigen zeit wohl eher die ausnahme sein. es gibt bei einigen herstellern seit über 2 jahren artikel in preislisten, welche noch nie real gesichtet wurden. irgendwann erfährt man dann ganz beiläufig, das es diesen artikel nie geben wird.... noch schlimmer ist dann aber die ersatzteilversorgung. es kommen modelle (speziell meine ich hier einen kleinen heli, welcher im november das erste mal verfügbar war und für welchen es erst anfang januar die ersten ersatzteile gab) auf den markt, wo es erst monate später überhaupt ein ersatzteil gibt.... bleibt nur zu hoffen, dass die endabnehmer sich zukünftig überlegen, welche firmen sie mit dem kauf der entsprechenden artikel in zukunft unterstützen und am leben erhalten. was nützen mir in immer kürzeren abständen neue modelle, wenn es für diese dann keine ersatzteile gibt oder diese dann 1 jahr später nicht mehr produziert werden? ich habe jedenfalls nicht die kohle um mir jedes jahr neue modelle anzuschaffen und werde entsprechend in zukunft genau drauf achten wie die hersteller ihre modelle pflegen und wie lange ich ein modell (ersatzteilversorgung) benutzen kann...
    mfg mahoney
    Manchmal hat man kein Glück..... und dann kommt noch Pech dazu!
    Chimera
    BeitragVerfasst am: 13.01.2009, 14:39    Titel:
    Bestes Beispiel: der LRP X12 und SXX TC Spec. Erstmals öffentlich(!) an der WM im November getestet/gezeigt und im März erhältlich bzw. die Motoren gibt es ja schon.
    Aber stimmt schon, bei Tamiya gab es ja auch mal so was mit dem ersten TRF Buggy, welcher nie gebracht wurde (basierte auf TRF 404 Layout). Selbst den TRF 404X gab es nur in extrem kleiner Stückzahl und nur in den USA für ne handvoll auserwählte Fahrer.
    Ist eigentlich schade, wenn viel Tam-Tam über ein Modell gemacht wird und es dann am Ende nie kommt. Da sollten sich die meisten Hersteller mal was besseres einfallen lassen Wink
    Mahoney
    BeitragVerfasst am: 13.01.2009, 15:04    Titel: ...
    das ist den meisten herstellern schei*-egal. die haben ihre dollarzeichen in den augen und wollen nur masse generieren um zu wachsen. die wenigsten hersteller legen ernsthaft wert auf eine dauerhafte und stabile kundenbindung. alle 4 jedes jahr zig neue modelle, die dann zur nächsten saison wieder eingestampft werden (incl. ersatzteile). das ist leider der normalzustand. was uns als händler (und modellsportler!!!) dabei ankotzt ist definitiv, dass hinweise auf diese philosophier bei den herstellern auf taube ohren stossen und wir uns mit den kunden "rumschlagen" müssen. die wenigsten verstehen aber, dass wir als händler keinerlei einfluss auf irgendwelche warenverfügbarkeit haben. solange sich da keine kritische masse findet, welche gemeinsam die hersteller anfängt zu "nerven" bzw. einige hersteller mal mit nichtkauf boykottiert, wird sich an der situation nichts ändern. die meisten händler haben wahrscheinlich ihre bemühungen schon aufgegeben und nehmen was sie bekommen. das diskutieren mit den herstellern um eine änderung herbeizuführen kostet unheimlich kraft und nerven. wir haben nicht nur 1x überlegt alles hinzuschmeissen.... getan haben wir es aber doch (noch) nicht. wir finden es nicht lustig, wenn uns die endanwender für die geldgeilheit und das fehlmanagement der hersteller verantwortlich machen. genau dies passiert aber und wir kommen kaum noch zum arbeiten, weil wir permanent irgendwem zu erklären versuchen warum es das bestellte ersatzteil oder dies oder jenes gerade nicht gibt.... selbst die einschlägigen fachzeitschriften "trauen" sich an eine offenlegung der unhaltbaren zustände im modellbau (noch?) nicht ran (werbeeinnahmen)Sad
    mfg mahoney
    heliman1
    Anmeldedatum: 11.01.2009
    BeitragVerfasst am: 15.01.2009, 18:53    Titel:
    hier kann ich mahoney nur zustimmen.
    Beim großen Zeh ist mir das leider schon mehrmals passiert. Aber es geht auch anders. Gestern wollte ich mir einen 1:16 Nitro-Buggy kaufen, und der Verkäufer hat doch tatsächlich gesagt "Das lassen Sie mal lieber bleiben. Damit hatten wir nur Probleme und der fliegt aus dem Programm."
    Andererseits wurde mir ein Monstertruck Ende 2007 wärmstens empfohlen, nur damit mir der Importeur (ich hatte mit dem Getriebe nur Probleme) 2008 auf der Messe in Dortmund sagt "Tja, schlecht gelaufen, den nehmen wir aus dem Programm und mit E-Teilen sieht es schon nicht mehr so gut aus. Verkaufen Sie den am besten umgehend."
    Sowas ist für die Kundenbindung an Waren aus Nürnberg auch nicht so toll.
    MfG
    heliman1
    Carpe diem!
    Keine neuen Beiträge Arrma Mojave EXB 1:7 Short Course Truck othello 14 25.12.2020, 15:26
    Keine neuen Beiträge Wir wollen eine neue Serpent Short Course Truck Generation Elektroman99 0 23.01.2020, 21:01
    Keine neuen Beiträge Arrma Mojave 6S BLX 1:7 Desert Truck Felix 4 16.09.2019, 19:17
