Tomt inaktiv
Verfasst am: 09.04.2010, 12:30 • Titel: RC4WD: 1:10 Bully RTR Crawler |
Winterer hat Folgendes geschrieben: |
RC4WD bringt einen neuen RTR Crawler raus.
Nach Yota & co, sind die Jungs wohl auf einer kleinen "RTR-Welle".
Der Preis liegt mit 499$ (ca. 380€) ein Stück über den RTRs von Losi,
Axial und anderen. Was man dafür bekommt könnt ihr hier lesen...
Zitat: |
The Bully is the most advanced MOA (Motor on Axle) competition crawler on the market. Not only is this crawler full metal, it also comes with many innovative features including unique V chassis with delrin skid plate, 40:1 gear radio bully axle, 8mm XVD (Xtreme Velocity Drive), round knuckles for extreme steering angle, clocked gear case, x-lock comp ready tires, 2.4Ghz Radio, comp-ready ESC/BEC, 45T brushed motor and aluminum beadlock wheels.
* Bully V chassis with laser engraved lettering
* Bully 2 alloy/machined axle
* Gear ratio: 38.41:1
* X-Lock 2.2 tires (5.5" / 140mm tall)
* Spark alum shocks with Ti shaft
* 15Kg high torque crawler servo
* 2.4Ghz radio & receiver
* Outcry dual motor ESC with BEC
* Aluminum beadlock wheels
* Meets all USRCCA required specs
* Full metal links with bent lower units
* Plastic Rod ends
* Full ball bearings
* Length: 17.5", Width: 10", Height: 6", Wheelbase: 12.5", Ground clearance: 2.5"
* Weight: 3kg/6.6lbs (with electronics)
What's included:
* 1x RC4WD Bully 1/10 RTR Crawler
Requires:
1x Crawler body, 1x battery and 1x charger.
Part number Z-RTR0002
Retail Price $499.99
http://rc-bayern.foren-city.de/topic,11,-rc4wd-1-10-bully-rtr-crawler.html |
