 Hier klicken für die Deutsche Fassung!
Hot Bodies Cyclone D4
Review, part #2
 Gentlemen ...
Blazing sunshine from a cloudless sky, with temperatures beyond 30 degrees Celsius and the almost dust-free track of RMC-Vienna: this is track-test-day no. 1!
The RMC-Vienna offers the perfect track for offroad enthusiats The track layout should be familiar with drivers who participated in the 2006 euros. The track didn't change since then.
EQUIPMENT USED FOR TESTING
RC: Sanwa M11 & RX-211
Steering: Sanwa VX
ESC:
    Nosram Matrix Evolution
    2007 Edition
Motor:
    LRP Vector X11 5.5/6.5
Battery:
    LRP VTEC 4200 HV² FT
All external Hyperlinks marked like this will be openend in a new browser window!
 ... start your engines!
I started out calmly, being easy on the throttle as I drove the Cyclone D4 around the track. I wanted to get a feeling for the new racer, and both slipper and diffs needed some time to break in.
After I had dialed in the ESC, I went straight up to the driver’s stand. The outcome after the first battery dumped: quite visible enthusiasm in my face!
Click on the pictures to get an enlarged view!
It was just fun to drive the buggy around the demanding track. The next runs were dedicated to a photo-shooting to give you an impression of how the Cyclone D4 looks like on a track.
For the rest of the day, I didn’t change anything in the setup department. It was just that the ESC and motor weren’t yet working to my full satisfaction.
(Click on the picture for an enlarged view!)
 The second day at the track
Just the next day: same weather conditions, same buggy, same driver, but different track. This time, Hot Bodies Cyclone D4 had to face MAC Traiskirchen’s track. Due to the grip level being comparable to the RMC Vienna track, the D4 performed well with its stock-setup there too, taking the corners with ease.
But the moment of truth became imminent as I was about to equip the Cyclone D4 with a transponder. This not only meant instant feedback for my setup-work, but it would also pit the Cyclone D4 against JConcepts BJ4 Worlds Edition which I drove on the same track earlier this year.
To be honest, the comparison between these two cars wasn’t completely fair yet, since the BJ4 was equipped with a front one-way and the Cyclone D4 still had a front diff.
But the numbers looked promising as I was only 0.3 of a second behind the BJ4’s best time. Compared to the BJ4 equipped with a front diff too, the Cyclone could beat it by about 0.4 seconds.
To further fine tune the D4’s performance, I changed to lighter 25wt oil and relocated the camber links a little. (You can download a setup-sheet towards the end of this review.)
 First Race!
Towards the end of August, I took the chance to test the Cyclone D4 under racing conditions. Therefore, the 5th round of the Austrian nationals, held at the PSV-Salzburg was the perfect opportunity.
The track was completely new to me, and the participation of many local drivers with their home field advantage made up a very competitive starting grid.
I started out with my setup from Traiskirchen, still featuring the stock front diff. Proline’s Holeshot tires were used front and rear, as the OEFMAV regalement requires.
The less than average grip levels made it difficult to find a working setup for the track. Solely changing over to a front one-way improved things and made the D4 more aggressive at the entrance of the turns.
I wasn’t alone with my setup-difficulties. Basically anybody else had to struggle to keep up with the fierce competition from the local drivers.
So, the reason for my worst performance this year (8th place) was by far not the car’s fault, rather the extremely challenging track conditions for foreign drivers.
On a side note: Maintenance work was absolutely easy to do and the Cyclone D4 reacted predictably to the slightest setup changes. The Cyclone D4 showed its potential and the setup is still workable.
Brushless-excursion: Brushless motors clearly dominated this year’s Austrian nationals. 9 out of the top 10 4wd drivers used brushless systems, mostly from LRP/Nosram. Gone are the days, were brushless systems were associated with bad throttle control and reliability, and hardly anyone can imagine going back to brushed motors.
Gone are the days of tedious motor maintenance, brushless let’s you focus more on the car and its setup.
My recommendation for the Cyclone D4 would be a brushless motor with 5.5 to 6.5 turns, depending on the track layout.
After countless runs, no alarming wear on the Cyclone D4 could be noticed. The feared diff screw breakage didn’t happen to me, but it loosened up a bit due to a faulty diff spring. With the spring replaced, and some thread lock on the diff nut, the diff was as good as new again.
Crash damages were also kept at a minimum: A broken front arm and a partially fractured shock tower where all, the Cyclone D4 suffered in a head-on collision at the end of a straight.
To give the track test a broader approach, I invited another D4 driver, Rene Levetzow, (overall 6th in the Austrian championships) to give a few statements on the Cyclone D4’s performance:
  • Handling:
    Handling-wise, Hot Bodies Cyclone D4 is very forgiving. A particular advantage compared to my former JConcepts BJ4 WE is the D4’s tremendous rear end grip that comes in handy on slippery tracks.
    The best grip balance is achieved with the front one-way.
  • Durability:
    The D4’s durability is good, but there are two shortcomings:
    First, the shock shafts don’t feature an abrasive resistant coating like Associated or Team Losi shock shafts.
    Second, the hinge pins seem to be made of a soft material which bends easily on impact.
 The final statement
After the build, I was very enthusiastic for Hot Bodies' Cyclone D4 - and at the track, my high expectations were fulfilled. The buggy leaves nothing to be desired, and with its maintenance-friendly construction, working on the D4 is very easy.
The car’s handling is very balanced and for me, the kit setup worked considerably well on most tracks.
Make sure, your pit box doesn’t miss arms, front shock towers and hinge pins!
Special thanks to:
LRP-Electronic
The author further wants to thank:
  • LRP electornics - who did not only supply the review sample, but also provided a Vector X11 brushless motor and some nice batteries
  • HOECO – who provided a Nosram Evolution brushless controller
  • Georg Würger – for his perfect airbrush work
  • and Aaron Banovics from offroad-CULT, who invited me to review the Cyclone D4
Written by Florian Klemm
Translation and pictures by Aaron Banovics
This article has been published by www.offroad-cult.org on 9-9-2007.
Aktuelle Testberichte von offroad-CULT:
LRP 90W High Power Lötstation: Dicke Kabelquerschnitte,  bleifreie Lote: Hochleistungselektronik mit neuen Kabeln auszustatten, ist für den guten alten Baumarkt-Lötkolben keine so leichte Aufgabe mehr. Doch wie schlägt sich LRPs Lötstation mit den modernen Komponenten? Der Testbericht verrät es!
Team Orion Carbon FLX 3s 6000: Team Orions Custom Lipos speziell für den Savage Flux - hier auf offroad-CULT im 12-monatigen Langzeit-Test!
LRP iX8 und Dynamic8 - LRPs zweite Generation der 1/8 Brushless-Komponenten Hier geht's zum Testbericht!
LRP VTEC Competition Line 5900/50C - Der Nachfolger der bewährten 5300/40C Competition Line im Detail: Hier geht's zum Testbericht!
LRP SPX8 und Vector8 - offroad-CULT testet LRPs 1/8 Brushless Komponenten! Weiter zum Testbericht
LRP VTEC Competition Line 5300/40C - Der neue Hardcase-Lipo auf dem Prüfstand: Hier geht's zum Testbericht!
LRP S8BXe Team - LRPs Premiere in Sachen 1/8 Brushless Buggy. Der S8BXe Team ist einer der ersten serienmäßigen 1/8 Buggies für die neue Antriebstechnik. Offroad-CULT präsentiert den umfassenden Testbericht und deckt alle Mankos auf - Top oder Flop? Weiter zum Testbericht.
HPI-Racing SAVAGE FLUX - offroad-CULT testet den ersten serienmäßigen Brushless Monster-Truck und zeigt auf mehr als 45 A4-Seiten, was die Community von HPI-Racings neuem Premium-RTR erwarten kann - weiter zum Testbericht!
LRP S8BX - ein ausführlicher Erfahrungsbericht über LRPs 1/8 Offroad-Debüt! LRPs S8BX bringt zahlreiche innovative Features wie die adaptive Hinterachse oder ein neuartiges Bremssetup mit ins Rennen - doch wie praxistauglich ist das neue Konzept? (Einen ausführlichen Aufbaubericht gibt es hier!)
HPI-Racing E-Firestorm FLUX - RTR meets brushless und wir testen!
Im gewohnt dreiteiligen und ausführlichen Testbericht wird HPI-Racings Erstlingswerk in Sachen Brushless-RTR in all seinen Details genauestens unter die Lupe genommen.
Ansmann Racing Master-Smacker und Royal Flash - offroad-CULT lädt zum großen Doppel-Review!
In einem dreiteiligen Testbericht werden die neuesten Ansmann-Offroader ausführlich vorgestellt, miteinander verglichen und abschließend auf Herz und Nieren durchgetestet.
Losi Desert-Truck RTR - der heißersehnte 1/10 Stadium im Test!
Auf umgerechnet über 40 A4-Seiten stellt offroad-CULT Losis neuen RTR-Offroader vor und unterzieht ihn wie gewohnt knallharten Konstruktions-Checks und schonungslosen Tracktest-Sessions!
Günstig oder billig? Mit der neuen Dragster-Sport Brushless-Combo stößt Carson preislich in die Region von Bürstensetups vor. Doch ob die Performance eines Brushless-Systems würdig, oder ob der Griff zum Bürstensetup der Bessere ist, klärt unser Testbericht!
Einer für alle! GM-Racings Genius-Controller können Bürstenmotoren und bürstenlose Motoren mit und ohne Sensorunterstützung ansteuern. Was der hier gezeigte Genius 85 sonst noch so zu bieten hat, deckt unser Testbericht auf!
Was kann man von einem Modell zwischen Einsteigerbuggy und High-End Offroadmaschine erwarten? Wie schlägt sich Tamiyas neuer Durga DB01 im Vergleich zur Kyosho und Academy-Konkurrenz? Unser Testbericht klärt's!
Team Orion Carbon Edition 3600 Race Spec: Team Orions zur Zeit schärfster Hardcase-Lipo - auf dem Prüfstand!
INTERNATIONAL RELEASE available here!
Kyoshos Lazer ZX-5 Readyset ist eine preisgünstige Alternative zum Lazer ZX-5. Das RTR-Modell nimmt mit einem UVP von 269 Euro einen Platz in der sonst recht leeren Mittelklasse ein. Geht der Wunsch vom ambitionierten, leistbaren 4wd Rennbuggy für den Hobbyfahrer damit in Erfüllung... ?
Team Losis CR-Generation im Test, Teil 2: Auch der Stadium-Truck ist seit Kurzem als "CR"-Version erhältlich. Grund genug, den XXX-T cr zum offroad-CULT Härtetest vorzuladen und ihn auf Herz und Nieren durch zu checken!
Team Losis CR-Generation im Test, Teil 1: Im ersten Teil dieses Doppel-Tests lädt Losis XXX-cr zur Testfahrt ein. Fast 8 Jahre XXX-Plattform: Was hat sich geändert? Was wurde verbessert? Und was bringt's unterm Strich für den Fahrer? Hier geht's weiter zu unserem Testbericht!
Wettbewerbsbuggy goes RTR: Thunder Tiger bringt das bisherige Flaggschiff-Modell, den EB4 S3 in RTR-Neuauflage auf den Markt.
Was die RTR Ausstattung taugt und welche Figur der EB4 S3 RTR in der Praxis macht, klärt unser 58-seitiger Exklusiv Testbericht!
Hot Bodies neuer Allrad Racer: Mittelmotor, zweiteiliger Kardanantrieb mit Kegelrad-Getriebeboxen und Saddlepacks - so sieht das aktuelle 4wd Design-Dogma aus. Der Cyclone D4 setzt dieses auch kompromisslos um, doch wie macht er sich auf der Rennstrecke?
Stadium-Action zum Zweiten! Diesmal nehmen wir uns den Firestorm 10T von HPI Racing vor. Mit einer sympathischen Chassiskonstruktion und einem starken 3,0ccm Motor scheint er gute Karten zu haben -
aber reicht das für den offroad-CULT Härtetest?
INTERNATIONAL RELEASE soon
available!
Offroad-Einstieg um weniger als 150 Euro - ein guter Deal? Ist da nicht irgendwo ein Haken? Und überhaupt: Wie gut ist Ansmann Racings Smacker wirklich?
Der Budget-Buggy im offroad-CULT Test!
Reely / XTM-Racing X-Cellerator: Stadium Action zum Sonderpreis!
Ob sich der Stadium Truck lohnt, der hierzulande von Conrad Electronic vertrieben wird, stellen wir in unserem Testbericht fest!
available here!
Der Truggy im Kleinformat: Nach dem "Shark 18" 4wd Elektrobuggy im Maßstab 1:18 präsentiert uns LRP nun die Truggy-Version als Shark 18 Monster. Wir haben die RTR-Version ausführlich getestet!
available here!
Truggies liegen voll im Trend - klar dass Kyosho als eine der ganz großen Marken am 1/8 Offroad-Sektor dabei ist. Mit dem Inferno ST US Sports sollen vor allem Einsteiger angesprochen werden - auch wir haben uns angesprochen gefühlt!
available here!
Keep it small and simple - dass "Monstertruck" nicht gleichzeitig "Monstermäßig" kompliziert bedeuten muss, will Jamara mit der Track-Sau vorzeigen und sie uns als erstklassiges Bashgerät präsentieren. Wahrheit oder Marketing-Gag? - unser Testbericht klärt's!
Der Robitronic Protos ist ein 1/8 Verbrennerbuggy der Einsteigerklasse: um 400 Euro (UVP des Herstellers) bekommt man einen Buggy komplett mit Fernsteuerung, Motor und Verbrennerzubehör. Wozu der Protos taugt, klären wir in unserem 24-seitigem Testbericht.
noch mehr Testberichte ...
