Aussenläufer im RC-Car
offroad-CULT Forum » Elektro - 1/8 » Aussenläufer im RC-Car »
    BeitragVerfasst am: 07.11.2004, 00:23    Titel: Aussenläufer im RC-Car
    Habe da einen interessanten Link gefunden
    http://www.cyclonbrushless.com/cyclon-intro.htm
    bzw
    http://www.cyclonbrushless.com/cyclon.html#Car
    Bei den Motoren handelt es sich um Aussenläufer die jedoch ganz "normal" montiert werden können.
    Die Motoren - obwohl Aussenläufer - können lt. Angabe bis zu 40000upm erreichen.
    Quote:
    This new range of High Speed Outrunner Motor has been developed with one objective: To have the best power to weight ratio in the world. This has been accomplished through one year of intensive effort in research and development. The new magnetic system is called " NFS " (Noro Fabrice System), the innovators name. The new system has many advantages. First it is based on the standard outrunner type motor, renowned for giving high torque. As Power = Torque X Speed, there is only one way to increase power, it is to increase RPM. Before Cyclon and NFS, this was not possible, because an increase in rpm means a computation increase above the speed of the controller’s capabilities; in brief the controllers processor is not able to compute fast enough for high revolutions with a 14 or 10 pole outrunner motor. Now it is possible with the new NFS system, with the new motors capable of up to 40,000 RPM, yet still giving the same torque as a 10,000 RPM outrunner motor. For the same size and weight as a standard outrunner motor, the power is up to 2 times higher than the standard outrunner motor format.
    eknl
    Anmeldedatum: 01.05.2004
    BeitragVerfasst am: 07.11.2004, 10:40    Titel: Re: Aussenläufer im RC-Car
    Moin .sehr interessant. Mal eine Frage dazu. Wenn man nur Bürstenpouver möchte , oder für enge Strecken, ist dieser dafü geeignet?
    Mini Cyclon Car
    Motor designed for mini Cars like Micro RS4, Mini Truck 1/18 scale. Can work with 6 to 8 cells or 2 Li-po cells, power up to 240 Watts, 7000 rpm/V.
    eknl
    BeitragVerfasst am: 07.11.2004, 10:41    Titel: Re: Aussenläufer im RC-Car
    ich meine jetzt für 1:10
    Reinhard
    Anmeldedatum: 23.01.2003
    BeitragVerfasst am: 08.11.2004, 13:28    Titel: Re: Aussenläufer im RC-Car
    Cyclon Car 7500
    Motor for Dragster 1/10 with 6 Cells, or DTM 1 /12 with 4 cells
    7500 Rpm / V, Power: 700 W with 6 cells. 480 W with 4 cells.
    700Watt aus 6 Zellen ???
    das wären ja 700 / 7.2V = 97A !!!
    nur dass bei 97A die spannung NIE bei 7.2Volt ist..
    wohl eher bei 5Volt bzw. weniger..
    wodurch - für die 700Watt - der STrom noch weiter raufgehen müsste..
    also ich denk, es is sehr zweifelhaft, ob man überhaupt jemals 700Watt aus nem 6 Zeller rauskriegen kann..
    der Mini-Cyclon scheint nur 50g zu wiegen --- NEIN, nicht für 1:10 geeignet..
    ausserdem: 7000U/min/Volt
    der dreht somit an die 50.000U/min
    gibt somit kein Auto wo man den sinnvoll übersetzt einsetzen könnte
    also wie auch immer: der Motor ist wohl als Ersatz für 280er und 300 Motoren geeignet..
    Mr. Constructor
    Anmeldedatum: 10.11.2004
    BeitragVerfasst am: 10.11.2004, 15:55    Titel: Re: Aussenläufer im RC-Car
    Tja, diese Motoren gehen eher schlecht in nem 1:10er, da die Regler häufig die Problematik Coggingfreies Anlaufen und trotzdem Proportionale Bremse selten gut unter einen Hut bekommen, vom anderen Timing (weil bis zu 14 poler) ganz zu schweigen, dennoch, es geht und funktioniert einwandfrei, ich werde mal nen paar Fotos eines ca 4,5 kg schweren (da total aus Titan) 1:8er Buggys mit nem Torcman 350 Motor Posten (der Emaxx geht auch sehr gut mit derlei Motoren, schaut mal beim Motorenhersteller nach, dort ist das Auto zu sehen), diese Fotos sind einigen bekannt aus dem Amiforum, dies ist nun der Deutschsprachige Part, das andere Deutsche Forum wird ja eher stiefmütterlich behandelt, daher lieber hier:
    Anstelle der alten Firmenseite wird es demnächst ein Museum von diversen Elektro RC Cars geben: www.ace-cars.de.
    Mr. Constructor
    BeitragVerfasst am: 10.11.2004, 15:57    Titel: Re: Aussenläufer im RC-Car
    Hier mal ein neueres:
    (der Motor ist total in der Mitte untergebracht, daher ne sehr gute Verteilung des Gewichtes.)
    Keine neuen Beiträge Aussenläufer im RC-car ? Reinhard 4 29.10.2007, 03:31
    Keine neuen Beiträge Direkt-Antrieb E-Maxx mit Aussenläufer Reinhard 6 26.04.2007, 11:03
    Keine neuen Beiträge Aussenläufer Hellfire iss fertig Erkan 15 31.03.2007, 15:14
    Keine neuen Beiträge Brushlessregler für Aussenläufer Aussenläufer 3 11.08.2006, 07:31
    Keine neuen Beiträge Staubschutz für Aussenläufer? Servant of God 3 23.07.2006, 21:48
