Chimera CULT-Urgestein
Verfasst am: 26.12.2008, 15:36 • Titel: Kyosho Desert Race Truck RTR 1/10 |
Nun bringt auch Kyosho nen Desert Race Truck in der Nitro Version. Basierend auf dem gleichen Chassis wie der DBX/DST kommt der Truck mit folgenden Ausstattungsdetails:
"GXR .18
New GXR .18 now delivers monster torque and power with Kyosho?s proven reliability.
Massive 105cc Fuel Tank
Includes newly designed 105cc fuel tank to supply the large 18-size engine. Delivers stable fuel supply even under severe driving conditions. Can deliver run times of more than 10 minutes.
Compatibility
80% of DST/DBX parts and option parts are compatible with the DRT.
No Guess Work
Lower suspension arms are both the same front and rear, this takes out all the guess work with part numbers.
Fully Interchangeable
Front / rear and left / right suspension arms, front / rear knuckles and front / rear shock stays are all interchangeable. Newly designed suspension with maintenance-friendly ball connect system.
Dirt Proof Radio Box
Dirt-proof radio box protects the receiver and battery box from the outside elements. It can be attached or removed from the chassis with just four screws for easy maintenance.
Fully Digital Servos
A new two-channel radio is included with the GT2. The radio features throttle and steering trim adjustments, dual-rate to simultaneously increase or reduce left and right steering travel, and servo reversing switches for both channels. The servos are the digital variety for superior response.
Shaft Drive
The drive shafts run through the center for chassis to give you better lower CG and optimum weight balance.
QUELLE:RedRC.net _________________
MW Hop-Up Held
Anmeldedatum: 10.03.2008 Beiträge: 103
majus Offroad-Guru
Verfasst am: 26.12.2008, 22:24 • Titel: |
ich find das zusehr bei losi abgekupfert...aber sonst ganz schön (wobei ich persöhnlich elo´s zeitgemäßer finde und ich weiß,dass ich mir damit grade feinde gemacht habe )
mfg majus |
Verfasst am: 26.12.2008, 22:53 • Titel: |
da hat sich Kyosho vom DT und vom Slash inspirieren lassen  _________________ Ryan Dunn
R.I.P. Bro |
Basher 09 Hop-Up Held
Anmeldedatum: 21.04.2008 Beiträge: 127 Wohnort: Siebengebirge
Verfasst am: 28.12.2008, 17:48 • Titel: |
Trucks scheinen Momentan echt In zu sein, fast jede Firma bietet jetzt schon einen Truck an wobei ich auch sagen muss das die Elos glaube ich doch mehr verauft werden.
Die Entwicklung im bereich Elektronik is da doch etwas stärker als wie bei den Verbrennern z.B _________________ Das Leben ist wie ein Spiel...nur die Garfik ist geiler. =)__________________________________________
Fuhrpark: Traxxas E-Revo |
