m.velder neu hier
Anmeldedatum: 02.06.2008 Beiträge: 3 Wohnort: amsterdam
Verfasst am: 02.06.2008, 19:00 • Titel: |
Hello ,
My name is Michel and my son Jordy is driving the S8BX TEAM in Holland .
Our results with the car are very good , We changed the shocks into the Super Bigbore From Hong Nor , and filled them with 35wt LRP oil in the front and 20 wt in the back.
3000-5000-1000 in the diffs. Steering is excelent.
gr Michel |
CrowdPleazer neu hier
Anmeldedatum: 02.06.2008 Beiträge: 4
Verfasst am: 03.06.2008, 12:05 • Titel: |
Hello Michel!!
I must change my diff oils for sure... Everyone is using a "softer" setup on that things.
I am waiting for the release of the Big Bores from LRP and then i will give it a try... but the stocks ones are not bad at all i think...
Anyone knows when they will be available ??? (LRP Big Bores..)
Anyway,the steering in this car is always excelent
I will try to post my complete setup soon
Have fun!!! |
m.velder neu hier
Verfasst am: 10.06.2008, 12:22 • Titel: |
Do you guys also have problems with the brakesystem,?
gr M.velder |
Verfasst am: 11.06.2008, 01:20 • Titel: |
what kind of brake problems are you have??
After 2 gallons i have to reajust my brakes... after inspection i ve noticed that the little brake pistons become too small, They " go away " a little fast.
Is that the same problem that you have??
Gama |
m.velder neu hier
Verfasst am: 11.06.2008, 05:54 • Titel: |
Yes , in a race our brake pistons are gone in 7 minutes.
The wear is to much
gr M.Velder |
Verfasst am: 11.06.2008, 13:21 • Titel: |
7 minutes only??? Wow... something wrong there...
I just have too adjust my brakes after 2 gallons of fuel, and still have material in my brake pistons....
But i agree with you.
The wear is too much |
wunsche neu hier
Anmeldedatum: 14.06.2008 Beiträge: 2
Verfasst am: 14.06.2008, 20:46 • Titel: |
hello.i drive s8 from one week.
after an hour of testing I found only the rear shock a little too dry to answer.
discreet else.
i'm 2007 italian champion over 40 with losi 8.
I believe that the s8 has little excursion in suspensions.
someone had broken mechanical serious? I have a race on June 29 and I have not yet decided whether to use losi or lrp ....
you can have more my information here:
www.teampare.it
bye |
wunsche neu hier
Verfasst am: 29.06.2008, 20:04 • Titel: |
interregional first race, first victory.
problems at the oring of the stopper fuel tank ...
remedies??? |
Florian Offroad-Guru
Anmeldedatum: 14.02.2003 Beiträge: 942 Wohnort: Wiener Neustadt
Verfasst am: 29.06.2008, 22:45 • Titel: |
congratulations on your win.
best regards _________________ Team Powerflo |
ako Streckenposten
Anmeldedatum: 09.06.2006 Beiträge: 18
Verfasst am: 09.07.2008, 21:10 • Titel: |
hallo florian!
und? noch keine lust zum fahren?
gruss
alex |
