Asbjörn Pisten-Papst
Anmeldedatum: 20.11.2008 Beiträge: 418 Wohnort: Lübeck
Verfasst am: 12.06.2010, 16:25 • Titel: Mad Force Kruiser VE |
Hallo!
Kyosho hat Zeitgemäß auch den Mad Force Kruiser auf Brushless umgerüsted.
Infos:(english only)
Drivers will be blown away by the explosive acceleration as soon as the throttle trigger is pulled on this intimidating monster truck. Needless to say, wheelies are a breeze! The extraordinary power and performance comes from the Team Orion VORTEX brushless motor and ESC that combine to deliver simply breathtaking power and monster acceleration never seen before. With a heavy-duty chassis and drive train to back it up, the MAD FORCE Kruiser VE demonstrates superior durability. Also, the Readyset features a pre-assembled chassis, so just arrange your own batteries for the chassis and transmitter and a battery charger and you�re ready to bash in true monster truck power and style.
Features:
•Solid Axles - Solid axles are equipped with front and rear differentials that feature machine cut steel spiral bevel gears in a shaft drive 4WD chassis that delivers spectacular drive power.
•Longer Chassis - 30mm longer wheelbase compared to the original Mad Force and lowered suspension adds improved straight line and high speed cornering stability to the machine's hard charging performance characteristics.
•Improved Arm Position - Optimal position of suspension arms at 1G delivers improved maneuverability while retaining plenty of suspension stroke. Addition of rib reinforcements increases suspension arm rigidity.
•Big Bore Oil Shocks - Features heavy duty big bore oil shocks as standard. Takes even the harshest punishment for long periods without complaint and provides excellent damping power.
•Team Orion Vortex 8 - The Vortex 8 brushless motor and ESC combo is what powers the Inferno VE. The Team Orion Vortex 8 race spec ESC is equipped with a cooling fan system that will always be on to completely prevent any pebbles from jaming the fan. Compared to the current RTR ESC?s which the fan will only turn on when the FET temperature rises and cant engage due to a small pebble jaming it, causing overheating. Heat protection safe circuit, when this feature is activiated (automatically) the throttle fuction will shut down preventing any possible disaster. Auto Cut Off is another features on the Vortex 8 ESC, incase of a overload, the ESC will automatically cut off th protect the entire system. Auto battery detection, on/off switch is seperate from the ESC so its lotally replaceble in the need arises and also a dust switch cover as standard equipment.
•Hot-Rod Kruiser Body - Features new hot-rod truck body design. Pre-painted so you can enjoy the action in true truck style without delay.
•Chain Drive - Shaft and chain 4WD mechanism realizes highly efficient power transfer.
•Heavy Duty Chassis - Includes heavy duty black anodized chassis side plates that are 30mm longer than standard Mad Force.
•New Knuckle Design - New knuckle design increases control angles. This will give you a smaller turning radius, you can run circles around the competition.
•19mm or 14mm - Features 19mm hex hubs. Just remove the top 19mm hex to reveal a 14mm hex hub that can also be used.
•Steel Diff Gears - Ultra-strong steel diff gears are used in both front and rear diff to handle all the power being generated by the Vortex Motor.
•20 Ball Bearings - Total of 20 ball bearings used throughout the drive train for super efficient power transfer.
•Interchangable - Front - rear interchangeable suspension arms for efficient maintenance and parts utilization.
•KT-6 Transmitter - Equipped with a reliable KT-6 transmitter and radio system, all components are pre-installed.
•Vortex BL - The Vortex 2000kv brushless motor delivers powerful driving power from low to high RPM.
•Ideal Chassis Balance - Specified for 14.4V or 14.8V power from twin NiMH or LiPo batteries. Parallel battery layout realizes ideal balance for control stability.
•What is a Ready Set - �A Readyset is a fully assembled model that includes nearly everything you need to run. Body Color scheme is complete so only consumables like batteries and 7.4v Lipo x2 /7.2v NiMh x2 are required so you can start operating the model without delay.
Contents:
•Pre Assembled Chassis
•Pre Paintd Body
•Installed with Team Orion VORTEX 2000Kv brushless motor
•Installed with ESC for Team Orion VORTEX brushless motor
•Cross Wrench
Required For Operation:
•AA-sized alkaline batteries x 8 for transmitter
•Batteries for chassis (recommended All Peak Li-Po Power Series (2cell), Powerflo Lipo Series (2cell) or Power Plant NiMh Series (7cell Max))
•Proper charger for proper type of battery
Attention:
•Must have Super (Deans) plug.The default setting of the ESC is set for Li-Po battery mode. When using with NiMh battery packs, the setting will need to be changed to NiMh mode using the digital setup box(ORI65026 / Sold separately
Bilder:
http://www.kyoshoamerica.com/cars/index.php?part_num=30885#
wir in Amerika im September lieferbar sein.
Hoffentlich wird er nicht zu teuer.Sieht ja interessant aus.
mfg Asbjörn |
Verfasst am: 14.06.2010, 12:03 • Titel: |
UPE:499€
Ab October in Deutschland erhältlich. |
Nightstalker Offroad-Guru
Anmeldedatum: 16.07.2009 Beiträge: 509 Wohnort: Wien
Verfasst am: 14.06.2010, 13:49 • Titel: |
Interessantes Teil, ein Serien BL Modell mit mechanischer Bremse und Kettenantrieb, sowas hab ich noch nicht gesehen (wobei ich generell noch keine Kyosho Modelle aus der Nähe gesehen hab).
Schaut jedenfalls recht schnuckelig aus das Teil. |
Verfasst am: 15.06.2010, 16:08 • Titel: |
Ist schon ausergewöhnlich.
Noch nie Kyosho in der hand gehabt??Ich hab 3 Modelle.
Hab gerade geguckt:das ist keine Bremse,sondern die Lenkung (ziemlich umständlich,oder?) |
Canneloni Moderator
Verfasst am: 15.06.2010, 16:56 • Titel: |
Wo du es gerade sagst..... eine wow, relativ umständliche umlenkung  _________________ http://www.woodland-events.com
Verfasst am: 15.06.2010, 17:01 • Titel: |
Das ist so ziemlich das Merkwürdigste, was ich bisher gesehen habe. Sieht nicht so aus, als ob das ein Entwurf von 1970 wäre. _________________ Sind wir nicht alle ein bisschen Flux?
Ben Globaler Moderator
Verfasst am: 15.06.2010, 22:38 • Titel: |
Es ist ein ganz normaler gestreckter Mad/ Twin Force, so wie es ihn schon seit etlichen Jahren gibt... _________________ Leave Roll n' Roll to Rock n' Rollers |
Verfasst am: 16.06.2010, 07:31 • Titel: |
Stimmt. Ich bin ja noch nicht so lange dabei. Die Modelle kannte ich noch nicht. Wirkt auf mich aber nicht mehr zeitgemäß. Starrachse, Kettenantrieb, die umständliche Lenkansteuerung....
Sieht auch irgendwie sehr filigran aus. Kann man damit wirklich bashen, oder ist der Einsatzzweck ein anderer? _________________ Sind wir nicht alle ein bisschen Flux?
Verfasst am: 16.06.2010, 11:01 • Titel: |
Mad Force und die elektrifizierte Version Twin Force (Spirit) sind im Prinzip alte Bekannte.
Der Wheely King ist ja recht ähnlich aufgebaut - ein echter Scale Monstertruck mit Starrachsen und Längslenkern.
Einsatzzweck - bedingt durch die Bauart eine ideale Basis für Crawler Umbauten meiner Meinung nach. _________________ Ryan Dunn
R.I.P. Bro |
Savvage Hop-Up Held
Anmeldedatum: 11.05.2009 Beiträge: 117 Wohnort: Wolfsburg
Verfasst am: 16.06.2010, 14:30 • Titel: |
Bashen? Ich hab den Twin Force und er ist überhaupt nicht dafür gegeignet. Der Grund warum ich Kyosho zutiefst ablehne. 1 Extrem Schlechte Konstrktion 2. Überteuerte E-Teile 3. Einfach viel zu sehr bejubelt.
Mein Schadensbericht: Einmal in 3cm tiefem Schnee gefahren--Diff kaputt. Einmal gesprungen 15cm hoch--5 Verschiedene winzige Schrauben verloren
Ein Wheely--Bar fast abgerissen (Sieht schlimm aus.)
Das einzig brauhbare sind die Reifen und die fahr ich jetzt am Savi.
Mfg _________________ -Savage Flux ehemals X SS |
