Tomt inaktiv
Verfasst am: 08.04.2010, 17:34 • Titel: Spektrum: Digital Servos |
Spektrum wird uns nun auch mit Servos beglücken.
Mehr Infos auf: http://www.spektrumrc.com/
Zitat: |
S6040 Digital Surface Servo-High Speed
The S6040 combines the impressive ultra fast .08 second transit time with 167oz of torque and titanium gears. The coreless motor allows for extended motor life and a smoother operation. This performance, along with the smooth precision of its dual ball bearing output shaft and titanium gears, makes it the ultimate upgrade. Along with the Z connectors allows for compatibility with JR and Spektrum receivers. This is ideal servo for any vehicle enthusiast.
Key Features:
* Ultra fast 0.08 second transit time with 166 oz-in of torque at 6v
* Precise digital control
* Coreless motor for extended motor life and provides smoother operation
* Dual ball bearings provide less resistance for higher performance and longer life
* Z connectors are compatible with JR and Spektrum receivers
* 11 inch 22 guage wire
* Titanium gears for maximum durability and reliability
Product Specifications
Size Category: Standard
Type: Digital
Application: 1/10 Scale monster trucks, buggies and truggies
Torque: 12kg-cm / 167 oz-in @ 6V
Speed: 0.08 sec/60 degree @ 6V
Length: 40mm
Width: 20mm
Height: 37mm
Weight: 52g / 1.8 oz
Bushing Or Bearing: Bearing
Bearing: Dual
Motor Type: Coreless
Gear Type: Metal
Gear Material: Titanium
Voltage: 4.8 or 6.0V
$79.99
Zitat: |
S6030 Digital Surface Servo-High Torque
The heavy-duty, metal-gear S6030 puts out an incredible 278 oz-in of torque making it the perfect servo for 1/10-scale monster trucks, buggies and truggies. And it delivers this torque with silky smooth precision thanks to its dual ball-bearing output shaft.
Key Features:
* Delivers torque with silky smooth precision
* Heavy-duty
* Dual ball-bearing output shaft
Type: Digital
Application: 1/10 scale monster trucks, buggies and truggies
Torque: 20kg-cm / 278 oz-in @ 6V
Speed: 0.15 sec/60 degrees @ 6V
Length: 40mm
Width: 20mm
Height: 37mm
Bearing: Dual
Gear Type: Metal
$84.99
Quelle: www.rc-bayern.foren-city.de |
spinsV8 CULT-Urgestein
Verfasst am: 08.04.2010, 18:57 • Titel: |
ich schätze mal das sind die selben Modelle:
Abmessungen: 40,3x20x37,2 mm;
Gewicht: 52,4g;
Stellgeschwindigkeit/6 V: 0,15sec/60°;
Stellkraft/6 V: 20 kg-cm;
doppelt kugelgelagert;
Getriebe: Titan und Aluminium;
Gehäuse: Aluminiumkühlkörper;
Stromaufnahme: 0,18 A (Leerlauf), 1,7 A (Last)
Tomt inaktiv
Verfasst am: 08.04.2010, 20:04 • Titel: |
Jop. Und die Sävox sollen auch baugleich sein.
Aber wenns dann bei Spektrum/Horizon auch so einen guten Supprot
wie bei den Funken gibt.... |
Verfasst am: 08.04.2010, 21:57 • Titel: |
Tomt hat Folgendes geschrieben: |
Dazu kann ich nichts sagen!
Ist das Fakt oder Ironie? (ich denke mal Fakt!!)
@savöx:
ja, die sind auch baugleich! |
Tomt inaktiv
Verfasst am: 08.04.2010, 22:24 • Titel: |
Bei Spektrum funken gabs nie großartig Probleme mit Horizon.
Egal ob Display, Programmierung, etc...
Der Suprot von Horizon war eigentlich bisher gut. |
