Thor68 Hop-Up Held
Anmeldedatum: 26.01.2010 Beiträge: 81
Verfasst am: 02.05.2010, 11:51 • Titel: Tamiya TRF 201 1/10 2WD Buggy |
So nun noch mal das Erscheinungsdatum soll Mitte/Ende Juni sein.
Kann sogar schon in einem Shop vorbestellt werden.
Habe im Netz leider noch nicht wirklich viele Details gefunden.
Hat jemand vielleicht noch mehr Infos? |
sammy123 Globaler Moderator
Verfasst am: 02.05.2010, 12:06 • Titel: |
About the TRF 201
* This is a 1:10 R/C assembly model kit.
* Newly designed bath-tub type chassis with the motor mounted at rear.
* Chassis features a newly designed underside shape for an improved center of gravity
* whilst providing sufficient ground clearance.
* Newly designed sealed gearbox comes equipped with a ball differential.
* Newly designed front suspension arms are specific to 2WD buggies.
* Servo saver with built-in steering crank.
* Fully adjustable suspension.
* Includes aeration dampers for off-road cars.
* Traction control slipper clutch.
* Included front wheels are specific to TRF201 (compliant with IFMAR regulation).
* Included rear wheels are common to those from DB01 and TRF511.
* Rear universal shafts.
* Body, rear wing, tyres, motor, and R/C unit sold separately.
* Please note that TRF201 has nothing in common with the DT-02.
* Gearbox is equipped with a ball differential which features inch sized diff. balls (12pcs.), 2.6mm dia. diff screw, and newly designed thrust ball bearings.
* Diff. carrier features a new teeth shape to ensure a long-lasting performance.
* Suspension is fitted with assembly universal shafts.
* Aeration dampers feature new coil springs.
* Suspension has been designed to achieve excellent handling performance.
* Front axles are compatible with wheels using metric size ball bearings.
* The separately available body has aerodynamics that will assist in providing superior control over your machine and features a beautiful flowing design.
* Separately available wing set comes with 2 kinds of wings to further customise your settings.
* Chassis frame is made from fibreglass reinforced nylon resin and features a longitudinal battery position.
* Rear section is designed for optimised chassis roll balance.
* Chassis shaped is designed for an improved centre of gravity whilst providing sufficient ground clearance.
Tuning:
The following Spare, Option, and Limited Edition parts for the TRF201 buggy will also be released in conjunction:
* 51408 TRF201 B Parts (Motor Cover)
* 51409 TRF201 C Parts (Front Upright)
* 51410 TRF201 D Parts (Hub Carrier)
* 51411 TRF201 F Parts (Front Suspension Arm)
* 51412 TRF201 J Parts (Rear Suspension Mount)
* 51413 TRF201 M Parts (Damper Stay)
* 51414 TRF201 Front Dish Wheels
* 51415 TRF201 48 Pitch Spur Gear (79T)
* 51416 52T Ball Differential Gear Set
* 51417 6026 Thrust Bearing
* 51418 3x35mm Stainless Steel Shaft (2pcs.)
* 54210 TRF201 Body Ver.I
* 54211 TRF201 Rear Wing Set
* 54217 48 Pitch Pinion Gear (22T, 23T)
* 54218 48 Pitch Pinion Gear (24T, 25T)
* 54219 TRF201 48 Pitch Spur Gear (77T)
* 54220 TRF201 Front Axle (For 3/16” x 3/8” Bearings)
* 54221 TRF201 Front Spring Set
* 54225 TRF210 Lightweight Heatsink Motor Plate (Tentative)
* 84126 TRF201 Ti Screw Set
Mehr vernünftige Infos hab ich auch noch nicht gefunden. Gibt noch ein paar Bilder von der strecke, aber immer nur vom äußeren her.
Wie schon in einigen Foren geäußert find ich auch, dass er dem b4 schon recht ähnlich sieht
Ich denke Tamiya will jetzt auch mal wieder bei den 2wds ordentlich mitmischen.
Auch der Preis dürfte sehr interesant werden...
Und einige Teile scheinen ja zum TRF und db-01 kompatibel zu sein.
Bin mal gespannt
sammy _________________ RC-Rally! |
TheHavoc Offroad-Guru
Verfasst am: 20.05.2010, 10:45 • Titel: |
Schade, daß ich die News erst jetzt sehe. Hochinteressantes Fahrzeug, wie ich finde, nachdem was man da so zu erkennen glaubt. Werde ich auf jeden Fall mal im Auge behalten. _________________ Himoto Mega MT10; LRP S10; 2x Kyosho TwinForce
Hene neu hier
Anmeldedatum: 03.05.2010 Beiträge: 4
Verfasst am: 20.05.2010, 13:39 • Titel: |
Hat schon irgendjemand was über den Preis gefunden?
oder kann mir den Link zum shop schicken? |
Joda Pisten-Papst
Anmeldedatum: 19.03.2010 Beiträge: 480 Wohnort: Bielefeld
Verfasst am: 20.05.2010, 14:23 • Titel: |
Ich würde auch gerne den Shoplink haben .
Mfg Joda _________________ SWORKz S350 BK1 PSP ''e'' / TLR 22 2.0 (MM) / TLR 22 (RM) / Asso B5M / Tamiya DT-02 Desert Gator and more "Toys" |
Thor68 Hop-Up Held
Verfasst am: 25.05.2010, 08:01 • Titel: |
Habe noch ein paar neue Bilder gefunden.
http://juiced-rc.com/2010/05/tamyia-trf201/
Tamiya ist endlich auch auf dem richtigen Kurs, was die Schrauben angeht endlich Inbus (wenn das auch die Schrauben sind auf den Bildern, die dem Baukasten beiliegen).
Ich finde das Fahrzeug jedenfalls hoch interessant. |
Verfasst am: 25.05.2010, 08:21 • Titel: |
aber irgendwie nur ein weiterer Asso B4/Losi XXX Klon  _________________ Ryan Dunn
R.I.P. Bro |
RobertvonGoess Pisten-Papst
Anmeldedatum: 12.08.2007 Beiträge: 318 Wohnort: Wien
Verfasst am: 25.05.2010, 09:23 • Titel: |
Naja, die 2WD-Buggies lassen nicht viel "gestalterischen Spielraum" zu. Sehen alle irgendwie sehr ähnlich aus. _________________ Robert in Not. Kein Geld für Signatur vorhanden. |
Verfasst am: 25.05.2010, 11:17 • Titel: |
also wer nen asso b4 und nen Losi xxx vergleicht hat sich einfach nicht wirklich genau mit der Materie beschäftigt. Die Konstruktionen sind sehr unterschiedlich.
mfg Stephan |
Bibe neu hier
Anmeldedatum: 18.05.2010 Beiträge: 5
Verfasst am: 25.05.2010, 11:35 • Titel: |
schaut irgendwie fast so aus wie der mad rat oder x pro von ansmann. |
